AD9287 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-08-14
分享资料个
The AD9287 is a quad, 8-bit, 100 MSPS analog-to-digital con-verter (ADC) with an on-chip sample-and-hold circuit designed for low cost, low power, small size, and ease of use. The product operates at a conversion rate of up to 100 MSPS and is optimized for outstanding dynamic performance and low power in applications where a small package size is critical.
The ADC requires a single 1.8 V power supply and LVPECL-/ CMOS-/LVDS-compatible sample rate clock for full performance operation. No external reference or driver components are required for many applications.
评论(1)
发评论
2011-07-25
0 回复 举报
下不下来啊
管理员回复: 感谢您的反馈,现在可以下载了
收起回复
下载排行榜
全部1条评论
