MCP73828 pdf datasheet
消耗积分:2 | 格式:rar | 大小:1444 | 2008-08-14
郝埃连
分享资料个
The MCP73828 is a linear charge management controller
for use in space-limited, cost sensitive applications.
The MCP73828 combines high accuracy
constant voltage, controlled current regulation, cell preconditioning,
cell temperature monitoring, and charge
complete indication in a space saving 8-pin MSOP
package. The MCP73828 provides a stand-alone
charge management solution.
The MCP73828 charges the battery in three phases:
preconditioning, controlled current, and constant voltage.
If the battery voltage is below the internal low-voltage
threshold, the battery is preconditioned with a
foldback current. The preconditioning phase protects
the lithium-ion cell and minimizes heat dissipation.
Following the preconditioning phase, the MCP73828
enters the controlled current phase. The MCP73828
allows for design flexibility with a programmable charge
current set by an external sense resistor. The charge
current is ramped up, based on the cell voltage, from
the foldback current to the peak charge current established
by the sense resistor. This phase is maintained
until the battery reaches the charge-regulation voltage.
Then, the MCP73828 enters the final phase, constant
voltage. The accuracy of the voltage regulation is better
than ±1% over the entire operating temperature range
and supply voltage range. The MCP73828-4.1 is preset
to a regulation voltage of 4.1V, while the MCP73828-
4.2 is preset to 4.2V. The charge complete output,
CD10, indicates when the charge current has diminished
to approximately 10% of the peak charge current
established by the sense resistor.
The MCP73828 operates with an input voltage range
from 4.5V to 5.5V. The MCP73828 is fully specified
over the ambient temperature range of -20°C to +85°C.
评论(0)
发评论
下载排行榜
