TEMPO eSATA DATA CABLES:Tempo eSATA cables don’t compromise—why should you?
When using an eSATA Serial ATA host controller and connecting
external drive enclosures, you need Tempo eSATA
cables! Unlike thin, internal SATA cables, these cables offer
superior shielding and connectors with metal contacts to
provide enhanced EMI protection and improved durability
required for external use. These cables adhere to the design
specifications recommended by the Serial ATA International
Organization (SATA-IO), and are built to last.
