CAT4106 pdf,datasheet
消耗积分:3 | 格式:rar | 大小:277 | 2010-04-20
分享资料个
6 W Quad Channel DC/DC LED Driver with Diagnostics
The CAT4106 is an integrated multi−channel LED driver and high
power DC/DC converter suitable for powering backlighting
applications up to a total of 6 watts. Up to four matched LED strings
can be accurately programmed with uniform drive current set by a
single external resistor. Each output channel is suitable for LED string
voltages of up to 36 V. The driver automatically adjusts the output
voltage to drive the highest forward voltage string with the minimum
headroom voltage maximizing the efficiency.
评论(0)
发评论
下载排行榜
