LF355/LF356/LF357 pdf datasheet
消耗积分:10 | 格式:rar | 大小:444 | 2008-08-26
王芳
分享资料个
LF155/LF156/LF256/LF257/LF355/LF356/LF357
JFET Input Operational Amplifiers
General Description
These are the first monolithic JFET input operational amplifiers
to incorporate well matched, high voltage JFETs on the
same chip with standard bipolar transistors (BI-FET™ Technology).
These amplifiers feature low input bias and offset
currents/low offset voltage and offset voltage drift, coupled
with offset adjust which does not degrade drift or
common-mode rejection. The devices are also designed for
high slew rate, wide bandwidth, extremely fast settling time,
low voltage and current noise and a low 1/f noise corner.
评论(0)
发评论
下载排行榜
