TSC2003-Q1,pdf(I2C Touch Scree
消耗积分:3 | 格式:rar | 大小:502 | 2010-06-10
王银喜
分享资料个
The TSC2003 is a 4-wire resistive touch screen controller. It also features direct measurement of two batteries, two auxiliary analog inputs, temperature measurement, and touch-pressure measurement.
The TSC2003 has an on-chip 2.5-V reference that can be utilized for the auxiliary inputs, battery monitors, and temperature-measurement modes. The reference can also be powered down when not used to conserve power. The internal reference operates down to 2.7-V supply voltage while monitoring the battery voltage from 0.5 V to 6 V.
The TSC2003 is available in the small TSSOP-16 package and is specified over the –40°C to 85°C temperature range.
评论(0)
发评论
下载排行榜
