74F604/N74F604D pdf datasheet
消耗积分:2 | 格式:rar | 大小:666 | 2008-08-29
分享资料个
The 74F604 multiplexed latch is ideal for storing data from two input
buses, A or B, and providing data from either the A or B latches to
the output bus. Organized as 8-bit A and B latches, the latch outputs
are connected by pairs to eight 2-input multiplexers. A Select
(SELECT A/B) input determines whether the A or B latch contents
are multiplexed to the eight 3-State outputs. Data entered from the B
inputs are selected when SELECT A/B is Low; data from the A
inputs are selected when SELECT A/B is High. Data enters the
latches when the Latch Enable (LE) input is Low and is latched on
the LE rising edge. The outputs are enabled when LE is High and
disabled when LE is Low.
评论(0)
发评论
下载排行榜
