TL081,TL082,TL082c,TL084 pdf d
消耗积分:10 | 格式:rar | 大小:666 | 2008-08-29
分享资料个
The TL08x JFET-input operational amplifier family is designed to offer a wider selection than any previously
developed operational amplifier family. Each of these JFET-input operational amplifiers incorporates
well-matched, high-voltage JFET and bipolar transistors in a monolithic integrated circuit. The devices feature
high slew rates, low input bias and offset currents, and low offset-voltage temperature coefficient. Offset
adjustment and external compensation options are available within the TL08x family.
The C-suffix devices are characterized for operation from 0°C to 70°C. The I-suffix devices are characterized
for operation from −40°C to 85°C. The Q-suffix devices are characterized for operation from −40°C to 125°C.
The M-suffix devices are characterized for operation over the full military temperature range of −55°C to 125°C.
评论(3)
发评论
shangwei998 2015-08-06
0 回复 举报
网站不错,常来逛逛 收起回复
dinasourcui 2014-08-06
0 回复 举报
好吧 收起回复
全部评论
下载排行榜
全部3条评论
