FlashFlex51 MCU SST89E564/SST8
消耗积分:2 | 格式:rar | 大小:634 | 2010-06-30
笑过就走
分享资料个
FEATURES:
• 8-bit 8051 Family Compatible Microcontroller
(MCU) with Embedded SuperFlash Memory
• SST89E564/SST89E554 is 5V Operation
– 0 to 40 MHz Operation at 5V
• SST89V564/SST89V554 is 3V Operation
– 0 to 25 MHz Operation at 3V
• Fully Software and Development Toolset
Compatible as well as Pin-For-Pin Package
Compatible with Standard 8xC5x Microcontrollers
• 1 KByte Register/Data RAM
• Dual Block SuperFlash EEPROM
– SST89E564/SST89V564: 64 KByte primary
block + 8 KByte secondary block
(128-Byte sector size)
– SST89E554/SST89V554: 32 KByte primary
– Individual Block Security Lock
– Concurrent Operation during In-Application
Programming (IAP)
– Block Address Re-mapping
• Support External Address Range up to 64
KByte of Program and Data Memory
• Three High-Current Drive Pins (16 mA each)
• Three 16-bit Timers/Counters
• Full-Duplex Enhanced UART
– Framing error detection
– Automatic address recognition
• Eight Interrupt Sources at 4 Priority Levels
• Watchdog Timer (WDT)
• Four 8-bit I/O Ports (32 I/O Pins)
• Second DPTR register
• Reduce EMI Mode (Inhibit ALE through AUXR SFR)
• SPI Serial Interface
• TTL- and CMOS-Compatible Logic Levels
• Brown-out Detection
• Extended Power-Saving Modes
– Idle Mode
– Power Down Mode with External Interrupt Wake-up
– Standby (Stop Clock) Mode
• PDIP-40, PLCC-44 and TQFP-44 Packages
• Temperature Ranges:
– Commercial (0°C to +70°C)
– Industrial (-40°C to +85°C)
评论(0)
发评论
下载排行榜
