The LTC®3853 is a high performance triple output stepdown switching regulator controller that drives all N-channel synchronous power MOSFET stages. Power loss and supply noise are minimized by operating the output stages out of phase. The part can be confi gured as a dual phase controller plus a single phase controller if needed. The part can also be confi gured to provide a single 3-phase output for even higher output currents. A wide 4.5V to 24V (28V maximum) input voltage supply range encompasses most battery chemistries and intermediate bus voltages. Phase 3 can regulate output voltages up to 13.5V. A constant frequency current mode architecture allows for a phase-lockable frequency up to 750kHz. Independent TK/SS pins for each output ramps the output voltages and can be confi gured for coincident or ratiometric tracking. Current foldback limits MOSFET heat dissipation during short-circuit conditions. The MODE/PLLIN pin selects among Burst Mode® operation, pulse-skipping or continuous inductor current modes.
