AN5636K SECAM/PAL signal conversion IC n Overview The AN5636K is an IC which converts the SECAM signal into the quasi-PAL signal. This IC can add the SECAM signal processing function while rationalizing the external parts in a joint use with the PAL/NTSC signal processing IC: AN5606K. n Features · Rationalizing IHDL in common use with PAL IHDL · Lowering 6H line crawling by the quasi-PAL modulation · For both auto and manual modes of signal processing n Applications · TV (applicable to three systems: PAL/NTSC/SECAM)
