SN74LVC06A-Q1,pdf(Hex Inverter
消耗积分:3 | 格式:rar | 大小:144 | 2010-07-13
陆军航空兵
分享资料个
This hex inverter buffer/driver is designed for 1.65-V to 3.6-V VCC operation.
The outputs of the SN74LVC06A device are open drain and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions. The maximum sink current is 24 mA.
Inputs can be driven from either 3.3-V or 5-V devices. This feature allows the use of this device as a translator in a mixed 3.3-V/5-V system environment.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
评论(0)
发评论
下载排行榜
