SN74LVC2G14-Q1,pdf(Dual Schmit
消耗积分:3 | 格式:rar | 大小:289 | 2010-07-14
无人岛
分享资料个
This dual Schmitt-trigger inverter is designed for 1.65-V to 5.5-V VCC operation.
The SN74LVC2G14 contains two inverters and performs the Boolean function Y = A. The device functions as two independent inverters, but because of Schmitt action, it may have different input threshold levels for positive-going (VT+) and negative-going (VT-) signals.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
评论(0)
发评论
下载排行榜
