CY74FCT16244T,CY74FCT162244T,C
消耗积分:2 | 格式:rar | 大小:312 | 2010-07-15
分享资料个
These 16-bit buffers/line drivers are designed for use in memory driver, clock driver, or other bus interface applications, where high-speed and low power are required. With flow-through pinout and small shrink packaging board layout is simplified. The three-state controls are designed to allow 4-bit, 8-bit or combined 16-bit operation.
This device is fully specified for partial-power-down applications using Ioff. The Ioffcircuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
The CY74FCT16244T is ideally suited for driving high-capacitance loads and low-impedance backplanes.
The CY74FCT162244T has 24-mA balanced output drivers with current limiting resistors in the outputs.
评论(0)
发评论
下载排行榜
