CY74FCT16952AT,PDF(16-Bit Regi
消耗积分:2 | 格式:rar | 大小:517 | 2010-07-20
马占云
分享资料个
These 16-bit registered transceivers are high-speed, low-power devices. 16-bit operation is achieved by connecting the control lines of the two 8-bit registered transceivers together. For data flow from bus A-to-B, CEAB\ must be LOW to allow data to be stored when CLKAB transitions from LOW-to-HIGH. The stored data will be present on the output when OEAB\ is LOW. Control of data from B-to-A is similar and is controlled by using the CEBA\, CLKBA, and OEBA\ inputs.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
The CY74FCT16952T is ideally suited for driving high-capacitance loads and low-impedance backplanes.
评论(0)
发评论
下载排行榜
