HIP6018B pdf,HIP6018B datashee
消耗积分:2 | 格式:rar | 大小:666 | 2008-09-08
分享资料个
The HIP6018B provides the power control and protection for
three output voltages in high-performance microprocessor
and computer applications. The IC integrates a PWM
controllers, a linear regulator and a linear controller as well
as the monitoring and protection functions into a single
package. The PWM controller regulates the microprocessor
core voltage with a synchronous-rectified buck converter.
The linear controller regulates power for the GTL bus and
the linear regulator provides power for the clock driver circuit.
The HIP6018B includes an Intel-compatible, TTL 5-input
digital-to-analog converter (DAC) that adjusts the core PWM
output voltage from 2.1VDC to 3.5VDC in 0.1V increments
and from 1.3VDC to 2.05VDC in 0.05V steps. The precision
reference and voltage-mode control provide ±1% static
regulation. The linear regulator uses an internal pass device
to provide 2.5V ±2.5%. The linear controller drives an
external N-channel MOSFET to provide 1.5V ±2.5%.
The HIP6018B monitors all the output voltages. A single
Power Good signal is issued when the core is within 10% of
the DAC setting and the other levels are above their undervoltage
levels. Additional built-in over-voltage protection for
the core output uses the lower MOSFET to prevent output
voltages above 115% of the DAC setting. The PWM overcurrent
function monitors the output current by using the
voltage drop across the upper MOSFET’s rDS(ON),
eliminating the need for a current sensing resistor.
评论(0)
发评论
下载排行榜
