74AC11086,pdf(Quadruple 2-Inpu
消耗积分:2 | 格式:rar | 大小:379 | 2010-08-05
彭友旺
分享资料个
This device contains four independent 2-input exclusive-OR gates. It performs the Boolean function Y = A B = A\B + AB\ in positive logic.
A common application is as a true/complement element. If one of the inputs is low, the other input is reproduced in true form at the output. If one of the inputs is high, the signal on the other input is reproduced inverted at the output.
The 74AC11086 is characterized for operation from -40°C to 85°C.
评论(0)
发评论
下载排行榜
