MAX5873 pdf,MAX5873 datasheet
消耗积分:3 | 格式:rar | 大小:777 | 2008-09-11
而无返还
分享资料个
The MAX5873 is an advanced 12-bit, 200Msps, dual
digital-to-analog converter (DAC). This DAC meets the
demanding performance requirements of signal synthesis
applications found in wireless base stations and other
communications applications. Operating from 3.3V and
1.8V supplies, this dual DAC offers exceptional dynamic
performance such as 78dBc spurious-free dynamic range
(SFDR) at fOUT = 16MHz and supports update rates of
200Msps, with a power dissipation of only 255mW.
The MAX5873 utilizes a current-steering architecture
that supports a 2mA to 20mA full-scale output current
range, and allows a 0.1VP-P to 1VP-P differential output
voltage swing. The MAX5873 features an integrated
1.2V bandgap reference and control amplifier to ensure
high-accuracy and low-noise performance. A separate
reference input (REFIO) allows for the use of an external
reference source for optimum flexibility and
improved gain accuracy.
The digital and clock inputs of the MAX5873 accept
3.3V CMOS voltage levels. The MAX5873 features a
flexible input data bus that allows for dual-port input or
a single-interleaved data port. The MAX5873 is available
in a 68-pin QFN package with an exposed paddle
(EP) and is specified for the extended temperature
range (-40°C to +85°C).
Refer to the MAX5874 and MAX5875 data sheets for
pin-compatible 14-bit and 16-bit versions of the
MAX5873, respectively. Refer to the MAX5876 for an
LVDS-compatible version of the MAX5873.
Applications
Base Stations: Single-Carrier UMTS, CDMA, GSM
Communications: Fixed Broadband Wireless
Access, Point-to-Point Microwave
Direct Digital Synthesis (DDS)
Cable Modem Termination System (CMTS)
Automated Test Equipment (ATE)
Instrumentation
评论(0)
发评论
下载排行榜
