SN54LVC157A,SN74LVC157A,pdf(QU
消耗积分:2 | 格式:rar | 大小:790 | 2010-08-11
王强
分享资料个
These quadruple 2-line to 1-line data selectors/multiplexers are designed for 1.65-V to 3.6-V VCC operation.
The 'LVC157A devices feature a common strobe (G) input. When G is high, all outputs are low. When G is low, a 4-bit word is selected from one of two sources and is routed to the four outputs. The devices provide true data.
Inputs can be driven from either 3.3-V or 5-V devices. This feature allows the use of these devices as translators in a mixed 3.3-V/5-V system environment.
评论(0)
发评论
下载排行榜
