SN74CBT16210,pdf(20-Bit FET Bu
消耗积分:3 | 格式:rar | 大小:402 | 2010-08-16
王超
分享资料个
The SN74CBT16210 provides 20 bits of high-speed TTL-compatible bus switching. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device is organized as a dual 10-bit bus switch with separate output-enable (OE\) inputs. It can be used as two 10-bit bus switches or as one 20-bit bus switch. When OE\ is low, the associated 10-bit bus switch is on, and port A is connected to port B. When OE\ is high, the switch is open, and the high-impedance state exists between the ports.
评论(0)
发评论
下载排行榜
