SN74CBT3345,pdf(8-BIT FET BUS
消耗积分:2 | 格式:rar | 大小:406 | 2010-08-17
笑尽往事
分享资料个
The SN74CBT3345 provides eight bits of high-speed TTL-compatible bus switching in a standard ’245 device pinout. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device is organized as one 8-bit switch bank with dual output-enable (OE and OE)\ inputs. When OE\ is low or OE is high, the switch is on, and port A is connected to port B. When OE\ is high and OE is low, the switch is open, and the high-impedance state exists between the two ports.
评论(0)
发评论
下载排行榜
