FEATURES • TAS5414A – Single-Ended Input • TAS5424A – Differential Input • Four-Channel Digital Power Amplifier • Four Analog Inputs, Four BTL Power Outputs • Typical Output Power per Channel at 10% THD+N – 28 W/Ch Into 4 Ω at 14.4 Vdc – 45 W/Ch Into 2 Ω at 14.4 Vdc – 58 W/Ch Into 4 Ω at 21 Vdc – 116 W/Ch Into 2 Ω at 21 Vdc PBTL • Channels Can Be Paralleled (PBTL) for 1- Ω Applications • THD+N < 0.02%, 1 kHz, 1 W Into 4 Ω • Patented Pop- and Click-Reduction Technology – Soft Muting With Gain Ramp Control – Common-Mode Ramping • Patented AM Interference Avoidance • Patented Cycle-by-Cycle Current Limit • 75-dB PSRR • Four-Address I 2 C Serial Interface for Device Configuration and Control • Configurable Channel Gains: 12-dB, 20-dB, 26-dB, 32-dB • Load Diagnostic Functions: – Output Open and Shorted Load – Output-to-Power and -to-Ground Shorts – Patented Tweeter Detection • Protection and Monitoring Functions: – Short-Circuit Protection – Load-Dump Protection to 50 V – Fortuitous Open Ground and Power Tolerant – Patented Output DC Level Detection While Music Playing – Overtemperature Protection – Over- and Undervoltage Conditions – Clip Detection • 36-Pin PSOP3 (DKD) Power SOP Package With Heat Slug Up for the TAS5414A • 44-Pin PSOP3 (DKD) Power SOP Package With Heat Slug Up for the TAS5424A • Designed for Automotive EMC Requirements • Pb-Free Soldering Supported • ISO9000:2002 TS16949 Certified • – 40 ° C to 105 ° C Ambient Temperature Range
