These quad differential receivers accept digital data over balanced transmission lines. They translate differential input logic levels to TTL output logic levels.
The TB5R3 is a pin- and function-compatible replacement for the Agere systems BRF1A; it includes 3-kV HBM and 2-kV CDM ESD protection.
The power-down loading characteristics of the receiver input circuit are approximately 8 k
relative to the power supplies; hence they do not load the transmission line when the circuit is powered down.
The packaging for this differential line receiver is a 16-pin gull wing SOIC (DW) or a 16 pin SOIC (D).
The enable inputs of this device include internal pull-up resistors of approximately 40 k
that are connected to VCC to ensure a logical high level input if the inputs are open circuited.
