PCI2060,pdf(Asynchronous PCI-t
消耗积分:3 | 格式:rar | 大小:952 | 2010-08-30
duke刘
分享资料个
The Texas Instruments PCI2060 is a 32-bit, asynchronous, PCI-to-PCI bridge that is fully compliant with the PCI Local Bus Specification, Revision 2.3 and the PCI-to-PCI Bridge Specification, Revision 1.1. The PCI2060 bridge makes it possible for the primary and secondary bus clocks to be completely asynchronous and supports the PCI clock frequency up to 66 MHz.
The PCI2060 bridge is architecture-configurable for the PCI Bus Power Interface Specification. It can be configured to support either revision 1.0 or revision 1.1. Power conservation is made possible by using 1.8-V core logic with a universal PCI interface compatible with 3.3-V and 5-V PCI signaling environments.
The PCI2060 bridge allows the primary and secondary buses to operate concurrently.
评论(0)
发评论
下载排行榜
