PCI2250 Data Sheet Errata
消耗积分:2 | 格式:rar | 大小:78 | 2010-08-30
417804
分享资料个
1  ENUM# is NOT an open drain output.
2  Bridge may not be granted secondary bus when a secondary master asserts FRAME# at the same time that GNT# is de-asserted.
3  Hot Swap Control/Status Register behavior.
4  The I/O Window is closed if both I/O limit and I/O Limit Upper 16-bits registers are programmed to zero.
评论(0)
发评论
下载排行榜
