The Primarion Di-POLTM PX7520 Power IC is a highly configurable Digital Point-of-Load (POL) Controller with two PWM outputs for use in high current buck converter topologies. Up to four controllers from the Primarion Di-POL family can be synchronized for multiphase operation. The PX7520 provides PMBus™ compliant POL power regulation and supports current sharing and interleaving of multiple chips to balance the power supply currents. The PX7520 utilizes digital technology to implement all control functions, providing the ultimate in flexibility and stability. The PX7520 incorporates an industry standard PMBus™ compliant serial interface for control and monitoring. Through the serial interface, the power supply designer can quickly optimize designs and monitor system performance. The interface allows the PX7520 to provide digitized information for real time system monitoring and control. The PX7520 provides superior accuracy through internal calibration that measures and corrects current sense error sources upon startup. The PX7520 has programmable current sense temperature compensation that allows the designer to tailor the response for best accuracy over temperature. Superior accuracy reduces component count and solution cost.
