AM26C32,pdf(Quadruple Differen
消耗积分:10 | 格式:rar | 大小:783 | 2010-09-03
贾飞世
分享资料个
The AM26C32 is a quadruple differential line receiver for balanced or unbalanced digital data transmission. The enable function is common to all four receivers and offers a choice of active-high or active-low input. The 3-state outputs permit connection directly to a bus-organized system. Fail-safe design specifies that if the inputs are open, the outputs are always high.
The AM26C32 devices are manufactured using a BiCMOS process, which is a combination of bipolar and CMOS transistors. This process provides the high voltage and current of bipolar with the low power of CMOS to reduce the power consumption to about one-fifth that of the standard AM26LS32, while maintaining ac and dc performance.
The AM26C32C is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
