TAS5028A,pdf(8 Channel Digital
消耗积分:2 | 格式:rar | 大小:1347 | 2010-09-10
duke刘
分享资料个
The TAS5028A is an eight channel digital pulse width modulator (PWM) that provides both advanced performance and a high level of system integration. The TAS5028A is designed to interface seamlessly with most audio digital signal processors. The TAS5028A automatically adjusts control configurations in response to clock and data rate changes and idle conditions. This enables the TAS5028A to provide an easy to use control interface with relaxed timing requirements.
The TAS5028A can drive eight channels of H-bridge power stages. Texas Instruments H-bridge parts TAS5111, TAS5112, or TAS5182 + FETs are designed to work seamlessly with the TAS5028A. The TAS5028A supports both single-ended or bridge tied load configurations.
评论(0)
发评论
下载排行榜
