OPA320,OPA2320,OPA320S,OPA2320
消耗积分:5 | 格式:rar | 大小:306 | 2010-09-15
李鸿洋
分享资料个
The OPA320 (single) and OPA2320 (dual) are precision, RRIO, CMOS operational amplifiers optimized for very low noise and wide bandwidth while operating on a low quiescent current of only 1.45mA/ch.
The OPA320 and OPA2320 combine a wide bandwidth and high slew rate (10V/µs) with low noise (7nV/√Hz), low offset, and a 1pA maximum input bias current. These specifications make these devices ideal for a wide range of precision, time- and frequency-domain applications, such as high-impedance sensor front-ends, process control, or data acquisition systems.
The OPA320 and OPA2320 feature a linear input stage with zero-crossover distortion, delivering excellent common-mode rejection ratio (CMRR = 114dB, typical) over the entire input and supply voltage range.
评论(0)
发评论
下载排行榜
