OPA137,OPA2137,OPA4137,pdf(Low
消耗积分:3 | 格式:rar | 大小:397 | 2010-09-17
李军
分享资料个
OPA137 series FET-input operational amplifiers are designed
for low cost and miniature applications. In addition to small
size (SOT-23-5 and MSOP-8 packages), they provide low
input bias current (5pA), low quiescent currrent (220µA/
channel), and high open-loop gain (94dB).
Either single (+4.5V to +36V) or dual (±2.25 to  ±18V)
supplies can be used. The input common-mode voltage range
includes the positive supply—suitable for many single-supply
applications. Single, dual, and quad versions have identical
specifications for maximum design flexibility.
OPA137 op amps are easy to use and free from phase
inversion and overload problems found in some FET-input
amplifiers. High performance, including linearity, is main-
tained as the amplifiers swing to their specified limits. In
addition, the combination of high slew rate (3.5V/µs) and
wide bandwidth (1MHz) provide fast settling time assuring
good dynamic response. Dual and quad designs feature com-
pletely independent circuitry for lowest crosstalk and freedom
from interaction.
评论(0)
发评论
下载排行榜
