新型光子带隙微带贴片天线
消耗积分:3 | 格式:rar | 大小:344 | 2010-09-17
张强
分享资料个
提出一种新型光子带隙(PBG)结构微带贴片天线。在同轴线馈电型微带贴片天线的接地板上蚀刻出新颖PBG结构,通过数值仿真得到有效提高增益的结构。实际制作了PBG结构微带天线,并实测了天线特性参数。数值结果和实验结果进行了比较,取得了较为一致的结果.实测天线增益达8.8dB,比无PBG时提高约3dB,验证了该PBG结构的有效性。
关键词: 光子带隙结构,微带天线,天线增益
Abstract: This paper proposes a new PBG structure for microstrip patch antenna.A new PBG structure is etched on the ground plane of a probe-fed microsmp patch antenna.An efective structure for enhancing the antenna gajn is obtained by simulations.Such a PBG structure microstrip patch an tenna is fabricated and measured.NumericM results ale compared with the measured ones,showing good agreement.The measured gain reaches 8.8dB,which is about 3.2dB larger than that without PBG,verifying the validity of the PBG structure.
Key words: Photonic band gap(PBG)structure,Microstrip antenna,Antenna gain
评论(0)
发评论
下载排行榜
