TL103W,TL103WA,pdf(DUAL OPERAT
消耗积分:5 | 格式:rar | 大小:354 | 2010-09-18
分享资料个
The TL103W and TL103WA combine the building blocks of a dual operational amplifier and a fixed voltage reference — both of which often are used in the control circuitry of both switch-mode and linear power supplies. OPAMP1 has its noninverting input internally tied to a fixed 2.5-V reference, while OPAMP2 is independent, with both inputs uncommitted.
For the A grade, especially tight voltage regulation can be achieved through low offset voltages for both operational amplifiers (typically 0.5 mV) and tight tolerances for the voltage reference (0.4% at 25°C and 0.8% over operating temperature range).
The TL103W and TL103WA are characterized for operation from -40°C to 105°C.
评论(0)
发评论
下载排行榜
