LOG102,pdf(Precision Logarithm
消耗积分:5 | 格式:rar | 大小:488 | 2010-09-26
刘高
分享资料个
The LOG102 is a versatile integrated circuit that computes the logarithm or log ratio of an input current relative to a reference current.
The LOG102 is tested over a wide dynamic range of input signals. In log ratio applications, a signal current can be generated by a photodiode, and a reference current from a resistor in series with a precision external voltage reference.
In the block diagram shown below, A3 and A4 are identical, uncommitted op amps that can be used for a variety of functions, such as filtering, offsetting, adding gain or as a comparator to detect loss of signal.
The output signal at VLOG OUT is trimmed to 1V per decade of input current. It can be scaled with an output amplifier, either A3 or A4.
评论(0)
发评论
下载排行榜
