dg2706 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-09-29
石玉兰
分享资料个
DESCRIPTION
The DG2706 is a high speed, low voltage, low
On-resistance, quad SPDT (single pole double throw)
analog switch. It operates from a 1.65 V to 4.3 V single
power supply and achieves 3 Ω switch On-resistance. When
turned on, each switch conducts equally in both directions.
Its switch on resistance flatness is 0.6 Ω and channel to
channel matching is of 0.3 Ω when powered with single
3.15 V supply. All channels guaranteed break before make
switching.
Control logic input has 0.5 V to 1.65 V logic threshold. It
features a 190 MHz - 3 dB bandwidth, - 90 dB crosstalk and
- 70 dB off-isolation at 1 MHz.
The DG2706 is an ideal fit for low voltage battery powered
devices switching audio, video, multi-media data streams,
and control signals between different functional circuits or
ports.
The DG2707 comes in a small miniQFN-16 lead package
(1.8 mm x 2.6 mm x 0.75 mm). As a committed partner to
community and the environment, Vishay Siliconix
manufactures this product with the lead(Pb)-free device
terminations and is 100 % RoHS compliant
评论(0)
发评论
下载排行榜
