DG2032 pdf datasheet
消耗积分:2 | 格式:rar | 大小:555 | 2008-09-29
王利祥
分享资料个
The DG2032 is a monolithic CMOS dual single-pole/
double-throw (SPDT) analog switch. It is specifically designed
for low-voltage, high bandwidth applications.
The DG2032’s on-resistance (3  @ 2.7 V), matching and
flatness are guaranteed over the entire analog voltage range.
Wide dynamic performance is achieved with better than
–80 dB for both cross-talk and off-isolation at 1 MHz.
Both SPDT’s operate with independent control logic, conduct
equally well in both directions and block signals up to the
power supply level when off. Break-before-make is
guaranteed.
With fast switching speeds, low on-resistance, high
bandwidth, and low charge injection, the DG2032 is ideally
suited for audio and video switching with high linearity.
Built on Vishay Siliconix’s low voltage CMOS technology, the
DG2032 contains an epitaxial layer which prevents latch-up.
评论(0)
发评论
下载排行榜
