TPS65191,pdf(Triple High-Volta
消耗积分:3 | 格式:rar | 大小:1787 | 2010-11-03
48674
分享资料个
The TPS65191 is a triple high-voltage scan driver to drive an ASG (amorphous silicon gate) circuit on TFT glass.
Each single high-voltage scan driver receives logic-level inputs of CPVx and generates two high-voltage outputs
of CKVx, CKVBx. The device receives a logic-level input of STV and generates a high-voltage output of STVP.
These outputs are swings from Voff (–28 V) to Von (35 V) and are used to drive the ASG circuit and
charge/discharge the capacitive loads of the TFT LCD. In order to reduce the power dissipation of device, a
charge-share function is implemented. The device features discharge function, which shorts Voff to GND in order
to shut down the panel faster when the LCD is turned off.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
