dg2307 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-09-29
贾虎世
分享资料个
DESCRIPTION
The DG2307 is a single-pole-double-throw switch/2:1 mux
designed for 2 to 5.5 V applications. Using Vishay Siliconix
proprietary sub-micro CMOS process, the DG2307 achieves
low on-resistance, low power consumption. It is 1.6 V TTL
logic compatible across the operation voltage range. With its
low rON and low parasitic capacitance character, it is ideal for
clock signal and high speed data stream switching. It has low
insertion lost and negligible propagation delay.
The DG2307 can handle both analog and digital signals and
permits signals to be transmitted in either direction. When Bn
pin is at off status, the path will have a high impedance with
respect to the output. Break before make is guaranteed.
As a committed partner to the community and the
environment, Vishay Siliconix manufactures this product
with the lead (Pb)-free device terminations. For analog
switching products manufactured with 100 % matte tin
device terminations, the lead (Pb)-free "-E3" suffix is being
used as a designator.
评论(0)
发评论
下载排行榜
