针对Actel公司推出的Fusion系列混合信号FPGA,介绍了一种基于Fusion FPGA的无刷电机无位置传感器的控制器。试验结果表明,采用Fusion混合信号FPGA的无刷电机控制器具有集成度高,性能稳定,抗干扰能力强,控制精度高等优点。
- Abstract:
- iming at the mixed-signal FPGA of Fusion, A kind of sensorless BLDC motor controller is designed based on a fusion FPGA chip in this paper.The test? result shows that FPGA based on BLDC controller successfully works,high performance with high integrity, stability and precision.
