针对弹载存储测试技术,提出一种具有实时监测功能的弹载记录器,通过配套的测试平台和用户终端软件实时监测弹上环境和工作参数, 同时完成数据存储、分析和处理。通过导弹测量参数采集存储系统原理和实时监测模块设计的理论分析,软件仿真和实际测试验证该设计方案的可行性和监测模块的有效性。
- Abstract:
- Aiming at the missile storing and testing technology,a real-time monitor missile-embedded recorder is presented in this paper.The recorder can real-time monitor the environment and working parameters of missile by the test platform and terminal software.Simultaneity,the recorder can accomplish data memory,analyse and disposal.By the theoretical analysis of the system framework and the real-time monitoring module design,software simulation and actual testing,this paper verifies the feasibility of the design scheme and the validity of the monitoring module.
