基于FPGA的NoC验证平台的构建
消耗积分:3 | 格式:rar | 大小:803 | 2011-01-04
王芳
分享资料个
针对基于软件仿真片上网络NoC(Network on Chip)效率低的问题,提出基于FPGA的NoC验证平台构建方案。该平台集成可重用的流量产生器TG(Traffic Generation),流量接收器TR(Traffic Receiver)以及NoC软件,用于对NoC原型系统进行功能验证和性能评估。实际设计一个多核NoC,并用该平台对其进行FPGA验证,结果表明该平台的验证速度比软件仿真提高16000倍以上,并能对多种不同结构、路由算法、流控策略的NoC进行功能验证和性能评估。
Abstract:
 To solve the problem of Network on Chip(NoC)low efficiency based on software simulation,a FPGA based valida-tion platform construction scheme for Network on Chip(NoC)was proposed.This platform intergrates reusable modules of a traffic generation(TG),a traffic receiver(TR)and a NoC software,which are used to accomplish the function validation and performance evaluation.A NoC comprises many switching nodes was designed,and the NoC was validated by this plat-form.The experimental result shows that the speed of this platform reaches over16000times faster than software simulation;meanwhile,it can work on NoC which has different topology structure,routing algorithm and flow control strategy.
评论(0)
发评论
下载排行榜
