基于TQM7M5013下的 Quad-Band Input Power Controlled EDGE PAM
消耗积分:0 | 格式:pdf | 大小:0.23 MB | 2018-07-25
从未拥有
分享资料个
  Applications •
  Quad-Band GSM850 / GSM900 / DCS / PCS • GSM / EDGE / WEDGE Handsets • GSM / EDGE / WEDGE Wireless Cards
  Product Features
  • Digital Control Interface • Low Current At Backed-Off Power Levels • Input Power Controlled – GMSK & 8PSK • LB Has 4 modes – HP, MP, LP, & ULP • HB Has 3 modes – HP, LP, & ULP • HBT/PHEMT High Efficiency Technology • High–Power Linearity • Standard LB & HB Paths • 50 Ω Input & Output Impedance • Halogen-Free • 11 Pin Package
  General Description
  The TQM7M5013 is an input power controlled, multiple gain state, quad band, GSM/EDGE PAM designed for use with the Qualcomm QTR/RTR8600 WEDGE solutions. This highly efficient PAM significantly improves talk-time while still providing an easy to use solution in a small form factor. The PA output power is controlled by the input power coming from the transceiver in both GMSK and 8PSK modes and so does not require a Vramp input. Additionally, the small 5 mm x 5 mm package requires minimum board space and allows for high levels of phone integration.
评论(0)
发评论
下载排行榜
