The NET 2280 PCI to Hi-Speed USB 2.0 programmable peripheral controller is a highly integrated single chip device optimized for data transfer between a PCI bus and USB. NET 2280 is the ideal interface for intelligent Hi-Speed USB 2.0 peripherals that use PCI as the internal bus interface or a PCI-based local CPU. The NET 2280 is offered in a 14 x 14mm 120-pin TQFP or 8 x 8mm 121-ball FPBGA. This device is available in lead-free packaging.
