TIL3020 THRU TIL3023 OPTOCOUPLERS/OPTOISOLATORS
• 400-V Phototriac Driver Output
• Gallium-Arsenide-Diode Infrared Source
and Optically-Coupled Silicon Triac Driver
(Bilateral Switch)
• UL Recognized . . . File Number E65085
• High Isolation . . . 3535 V peak
• Output Driver Designed for 220 V AC
• Standard 6-Pin Plastic DIP
description
Each device consists of a gallium-arsenide
infrared-emitting diode optically coupled to a
silicon phototriac mounted on a 6-pin lead frame
encapsulated within an electrically nonconductive
plastic compound. The case withstands soldering
temperature with no deformation. Device performance
characteristics remain stable when
operated in high-humidity conditions.
