CS5157H CPU 5−Bit Synchronous Buck Controller The CS5157H is a 5−bit synchronous dual N−Channel buck controller. It is designed to provide unprecedented transient response for today’s demanding high−density, high−speed logic. The regulator operates using a proprietary control method, which allows a 100 ns response time to load transients. The CS5157H is designed to operate over a 4.25−20 V range (VCC) using 12 V to power the IC and 5.0 V or 12 V as the main supply for conversion. The CS5157H is specifically designed to power Pentium® II processors and other high performance core logic. It includes the following features: on board, 5−bit DAC, short circuit protection, 1.0% output tolerance, VCC monitor, and programmable Soft−Start capability. The CS5157H is available in 16 pin surface mount. Features • Dual N−Channel Design • Excess of 1.0 MHz Operation • 100 ns Transient Response • 5−Bit DAC • 30 ns Gate Rise/Fall Times • 1.0% DAC Accuracy • 5.0 V and 12 V Operation • Remote Sense • Programmable Soft−Start • Lossless Short Circuit Protection • VCC Monitor • 25 ns FET Nonoverlap Time • V2 Control Topology • Current Sharing • Overvoltage Protection • Pb−Free Packages are Available*
