The ML9372 is an organic EL cathode driver LSI with 64 outputs. Since this LSI has an output condition setting function, which allows setting of all outputs High, all outputs Low, and all outputs High Impedance, the user can set driving methods suited to the characteristics of an individual organic EL panel. When combined with ML936x, the organic EL anode driver series, the ML9372 can drive a full-dot panel.
