ML2213 pdf datasheet (Speech S
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-28
刘润生
分享资料个
The ML2213 is an ADPCM-based Speech Synthesizer LSI with on-chip 1.5 Mbit Mask ROM for storing multiple speech data. In addition, the LSI has a built-in Music Generator circuit that can generate music by automatically acquiring user-defined musical notes data from the ROM. The ML2213 contains a 12-bit D/A Converter and Low Pass Filter, and enables a user to readily built a message and music playback sub-system by simply adding an external speaker and driving amplifier.
评论(0)
发评论
下载排行榜
