ML2240 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-28
李伟
分享资料个
The ML2240 is a 4-channel mixing speech synthesis device which connects an external ROM expanded up to
128-Mbit (maximum). This ML2240 allows to select the playback method from the 8-bit PCM, non-linear 8-bit
PCM, 16-bit PCM, 2-bit ADPCM2, and 4-bit ADPCM2 algorithms. And the sound volume is adjustable as well.
The ML2240 incorporates a 14-bit D/A converter, and low-pass filter.
It is easy to configure a speech synthesizer by externally connecting a power amplifier and a CPU to the ML2240.
评论(0)
发评论
下载排行榜
