max232 串口转换芯片资料
消耗积分:10 | 格式:rar | 大小:333 | 2008-11-15
世态薄凉
分享资料个
The MAX232 device is a dual driver/receiver that includes a capacitive voltage generator to supply EIA-232 voltage levels from a single 5-V supply. Each receiver converts EIA-232 inputs to 5-V TTL/CMOS levels. These receivers have a typical threshold of 1.3 V and a typical hysteresis of 0.5 V, and can accept ±30-V inputs. Each driver converts TTL/CMOS input levels into EIA-232 levels. The driver, receiver, and voltage-generator functions are available as cells in the Texas Instruments LinASIC library. The MAX232 is characterized for operation from 0°C to 70°C. The MAX232I is characterized for operation from –40°C to 85°C.
评论(3)
发评论
bmam111 2012-07-30
0 回复 举报
多谢! 收起回复
zw84873018 2011-04-18
13 回复 举报
谢谢了。。 收起回复
全部评论
下载排行榜
全部3条评论
