RT9248A pdf datasheet (Multi-P
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-14
郝埃连
分享资料个
The RT9248A is a cost-effective multi-phase buck DC/DC
controller integrated with all control functions for GHz CPU
VRM. The RT9248A controls 2 or 3 buck switching stages
operating in interleaved phase set automatically. The multiphase
architecture provides high output current while
maintaining low power dissipation on power devices and
low stress on input and output capacitors. The high
equivalent operating frequency also reduces the component
dimension and the output voltage ripple in load transient.
RT9248A controls both voltage and current loops to achieve
good regulation, response & power stage thermal balance.
Precise current loop using RDS(ON) as sense component
builds precise load line for strict VRM DC & transient
specification and also ensures thermal balance of different
power stages. The settings of current sense, droop tuning,
VCORE initial offset and over current protection are
independent to compensation circuit of voltage loop. The
feature greatly facilitates the flexibility of CPU power supply
design and tuning.
The DAC output of RT9248A supports VRM9 & VRD10 by
VID125 multi-level input, precise initial value & smooth
VCORE transient at VID jump. The IC monitors the VCORE
voltage for PGOOD and over-voltage protection. Soft-start,
over-current protection and programmable under-voltage
lockout are also provided to assu
评论(0)
发评论
下载排行榜
