UM10058 pdf datasheet
消耗积分:3 | 格式:rar | 大小:638 | 2008-12-20
分享资料个
ISP1504 ULPI transceiver evaluation board, supporting Hi- Speed USB host, peripheral and OTG.
The ISP1504 is an 8-bit bidirectional UTMI+ Low Pin Interface (ULPI) transceiver, which
provides a Hi-Speed Universal Serial Bus (USB) analog front-end solution to Application-
Specific Integrated Circuits (ASICs) and Field Programmable Gate Arrays (FPGAs) to
implement as a Hi-Speed USB host, peripheral or OTG device.
The ISP1504 evaluation (eval) board allows designers to evaluate the features of the
ISP1504, and conduct system-level validation and testing. The eval board interfaces to
the link through a 100-pin Transceiver and Macrocell Tester (T&MT) connector that
complies with USB 2.0 Transceiver and Macrocell Tester (T&MT) Interface Specification
Ver. 1.2.
评论(0)
发评论
下载排行榜
